Entire video misaligned
COW Forums : VEGAS Pro
Bob Cain
on Jul 8, 2018 at 12:06:31 am
So I rendered this 10 minuted HD project - lots of velocity, FX, audio. I noticed that the video is misaligned, so the left is cut off and a strip of what SHOULD be there is moved over to the right. The bottom is also cut off, and what should be at the bottom is on a strip at the top. I went back to the project and discovered that the preview also shows this. Rendering at 1080p Internet Video template which is 29.97fps, all my source video is 30fps 1080p, with some 720p, text and images. FX bypass is not enabled. Project video match settings is enabled.
Download for the Screenshot for reference;
12515_image1.jpg.zip
Cheers,
Bob.
Raj Verma
Re: Entire video misaligned
on Jul 30, 2018 at 3:47:00 am
Seems to me that you are using an effect which has your video "x" and "y" values to reflect... Could you have possibly made an error using this effect which affects your entire clip?
