Clips skip to timestamps?
COW Forums : VEGAS Pro
Elliot Bruce
on Jun 29, 2018 at 9:40:46 pm
Okay, so im not too sure what to call this issue, hence the weird title.
I was editing my video, like i allways do then suddenly after reversing the playback on one clip i noticed i couldnt allign my audio and my video, the video file was snapping to one of the timecodes making this impossible.... I have no clue what i did and after reinstalling twice it still persists as an issue.. any fix? I should have attached a short clip of the iissue.
12492_skippingissue.mp4.zip
George Dean
Re: Clips skip to timestamps?
on Jun 29, 2018 at 10:50:14 pm
Hi Elliot,
I know you have re-installed, but have you done an application reset?
Hold down Shift+Ctrl keys and double click on you Vegas desktop shortcut. A window appears asking if you want to reset all Vegas Pro preferences to default? Before you select 'Yes', check the box to 'Delete all cached application data'.
This reset will set your installed version back to default installation values and delete any cached data that may be confusing Vegas.
Just a thought, this will often cure strange things!
Best Regards......George
Elliot Bruce
on Jul 1, 2018 at 9:03:41 am
Thanks for the reply! just went ahead and did that and it worked! thanks for the help!
George Dean
on Jul 1, 2018 at 4:19:54 pm
Sometimes that reset is like magic, other times, not so much!! Glad it worked out this time.
Best Regards.....George
