Mask through multiple video tracks?
COW Forums : VEGAS Pro
Joe Wik
on Jun 20, 2018 at 10:18:17 pm
I am trying to mask through 2 tracks.
On my first track I have some video effects generated. Below that track I have a still image. So the effect is moving in front of the still image.
But below these 2 video tracks there is an other image. I would like to create a circle mask through the 2 tracks and show the 3rd image in that mask which is the bottom track. (I need that 3rd image on the bottom as a separate track because I am also animating that, so in the masked circle there will be the bottom track animated.)
Is it something possible?
Joe
Graham Bernard
Re: Mask through multiple video tracks?
on Jun 21, 2018 at 2:54:35 am
[Joe Wik] "Is it something possible?"
My initial thought is that an Event Mask reveals that which is directly below that Event and not two Tracks below. Interesting. . . . I’ll have a go 😉
* Grazie
Graham Bernard
on Jun 21, 2018 at 4:08:58 am
[Joe Wik] "Is it something possible?"Hmmm? You gonna need to give more explanations
1] Upload a view of your Project Timeline
2] Just exactly what and where you've applied the FX on T1
3] Some indications of your Masking thus far.
You may have over-complicated this. Can you create a drawing of what it is you finally want?
* Grazie
Joe Wik
on Jun 21, 2018 at 8:16:02 am
Yes sure, I created an image to show what I am trying to do.
The blue background is my main image. Above that I have an other track and some video effects from a media generator (represented by the white lines).
So basically I need a circle where in that circle I can animate something. I could do this with only one track and mask that main image so we can look over it and see the animated image in the circle.
But now I want to add some effects over the main image.
Hope it explains a bit more what I am trying to do.
john bolton
on Jun 23, 2018 at 8:03:28 am
Just wondering if this was solved as I don't yet quite understand the sequence,
Anyway, do you mean something like this where you have a object in the Mask hole of the Main Image but also you want moving items on top of the Main image.. which seems to be what you are saying.. well it does to me ☺
https://www.youtube.com/watch?v=zZYLYloJmIQ
It may not be anything like this but was just thinking...but
Joe Wik
on Jun 23, 2018 at 9:05:17 am
Hi, Yes but the ball and the arrow should be behind the circle.
john bolton
on Jun 23, 2018 at 10:27:18 am
Ak OK...You said that " But now I want to add some effects over the main image ... not behind it with the others..
I will have a play
john bolton
on Jun 23, 2018 at 10:45:26 am
So all is behind the Main Image....
https://www.youtube.com/watch?v=RqJQNhefd20
If this is not what it is then maybe you can upload your Veg file so I/We can see what's what.
The moving items are only png files whereas you might be using animated gif for the items behind the Main Image?
The only animated gif I used is for the water ripples
Maybe Graham has figured it out....
Regards
Graham Bernard
on Jun 23, 2018 at 12:30:03 pm
[john bolton] "Maybe Graham has figured it out...."Nope. I haven’t got a ScoopyDoo.
Now where’s my Stella Artois? Watching Belgium v Tunisia. This has been, so far, a Classic World Cup of thrills, spills and chills.
* Grazie
Joe Wik
on Jun 23, 2018 at 2:27:53 pm
Ah no ☺
So the arrow and ball should move behind the whole animated circle. And not in the circle.
john bolton
on Jun 23, 2018 at 5:07:58 pm
Lets get this crystal clear....." So the arrow and ball should move behind the whole animated circle. And not in the circle"
Let's start at the beginning...
1) You have a MAIN IMAGE with a Masked hole in it ?
2) In the MASKED hole you have some sort of animation ?
3) You want the OTHER animations to move behind the FIRST animation.. In my case a DUCK?
4) What is the difference between .. "The Whole Animated Circle".. and NOT in the Circle?
What is the "The Whole Animated Circle".. which I assume is the LARGE HOLE... and NOT in the circle...which it the masked hole...
I guess we are missing some key explanation for myself and Graham who have not yet fathomed it out.
If you move items behind the MAIN image with the Masked hole you wont see them.. only where the MASKED hole is.
Last chance saloon...
John
George Dean
on Jun 25, 2018 at 10:08:31 pm
John, go back to your first illustration. I think what Joe wants is what you have there, the duck and water visible through the port hole, with your other animation of the arrow and ball in front of the main (background), but when the ball crosses the port hole the ball should go behind the port hole and not be seen, only seen on the background layer.
So the order would be blue background layer, ball and arrow animation overlaying the background (middle layer), port hole animation overlaying everything else (would be the top layer)
At least that is what I get from his explanation. Sure hope I haven't made it more confusing!! maybe I should have stayed out of it.
Best Regards......George
john bolton
on Jun 26, 2018 at 7:28:20 am
Ah OK George.. Yes... I guess you are correct..... hopefully.
Will gave a play.....
john bolton
on Jun 26, 2018 at 9:05:35 am
Had a think and a quick play
Do you think it is meant to be like this.
https://www.youtube.com/watch?v=biwXaZN51wA
Must be getting close now :)
john bolton
on Jun 27, 2018 at 6:42:22 pm
Here is another version where the Main Image items go behind the Masked Hole Item
https://www.youtube.com/watch?v=gohk478AidM
If it is not this then... Who knows... ☺
Regards
George Dean
on Jun 27, 2018 at 7:22:37 pm
By John Bolton:
"Had a think and a quick play
Must be getting close now :)"
That is what I think he means/wants, but apparently he got hung up on something and can't reply yet.
I surely think John you have covered just about all the possible combination of guesses there are, great job.
john bolton
on Jun 28, 2018 at 4:44:56 pm
Hi George and Graham or anyone else that knows the answer
I notice that sometimes where I add the CODE for the HTTPS link ( after highlighting the link and then pressing CODE ) it just show the link but on one of the links it shows YouTube embed?
Any clues and I have searched but found not solution
George Dean
on Jun 28, 2018 at 5:11:23 pm
I don't have the specific answer, but if you just copy the youtube URL and then paste it directly in your post, it should embed.
Best Regards.....George
john bolton
on Jun 28, 2018 at 8:09:59 pm
I did try that but it does not show in the preview.. Maybe it can't so I try as a test..
If it fails...then NP////
Test to see if this embed the video
john bolton
on Jun 28, 2018 at 8:10:37 pm
Oh it does... Thanks George... :)
George Dean
on Jun 28, 2018 at 11:17:42 pm
That has tripped me up more than once, by error trying to use the 'link', and I guess I'm not doing it correctly either, or have forgotten how to, so just paste direct. Glad it is working for you now.
