3d source alpha cut off image.
COW Forums : VEGAS Pro
Patryk Ciupa
on Jun 19, 2018 at 10:43:43 pm
Hello i have problem with me track motion (all in screen), others all ist good: Pan/Crop and, and. Where is problem? What can i do now?
Graham Bernard
Re: 3d source alpha cut off image.
on Jun 20, 2018 at 5:59:06 am
[Patryk Ciupa] "Where is problem? What can i do now? "
Interesting. I like your creativity. OK, try disengaging the FX Bypass. Presently you’ve got it Active:
Do you have any FX active? Also, can you upload the Track Header views? With all the 3D manipulations, plus pan/crop manipulations this is almost impossible to track down just why you are getting that “cut-off” without interrogating very closely the areas on the Timeline. Any chance of you uploading the VEG file?
* Grazie
Patryk Ciupa
on Jun 20, 2018 at 9:21:18 am
hello, when it comes to the preview it does not matter. Below I'm throwing screenshots and a link to the veg file. I would add that if I change the paramter from in "position" in "track motion" then this screen is longer and visible, but the problem is then with size adjustment. By changing the width and height parameters, I am not able to achieve a smooth effect. Sorry, for my English, but I use a translator. Regards.
Download veg files link: https://files.fm/u/gxrcxzz3
Patryk Ciupa
on Jun 20, 2018 at 9:40:39 am
Already everything is fine, the problem was trivial. On the last track, with white background, I do not know how the mask was set. Now everything is working correctly, thank you for your interest.
Graham Bernard
on Jun 20, 2018 at 2:34:00 pm
[Patryk Ciupa] "Now everything is working correctly, thank you for your interest."
I like a puzzle.
* Grazie
