Mask out of sync when rendered.
COW Forums : VEGAS Pro
David Gore
on Jun 11, 2018 at 11:03:46 pm
Hey everyone,
I've been having a very persistent issue when rendering masked footage. Despite being very tedious with the masking process, and it being in the right position in the preview window; the mask seems to always be off a few frames after being rendered.
Notes: I am using Vegas Pro 14. "Adjust source media to better match..." is checked in project properties. Project Properties are set to 29.970 (NTSC), as are the render settings - the footage is 56.794 fps. Disable re-sample was applied immediately after importing the footage > I then added Velocity before doing any masking (I did not adjust the velocity whatsoever subsequently to masking.) No plug-ins/affects have been added. I have tried, and would like to render as Sony AVC/MVC.
Any help will be greatly appreciated
