Obscured Wipe Transition
COW Forums : VEGAS Pro
alex ivanov
on May 31, 2018 at 11:24:26 pm
How do I make an "Obscured Wipe Transition" or whatever it's called? It's widely used in "My name is Earl" tv series, like here:
(start at 30 second). Thanks!
Paul Berk
Re: Obscured Wipe Transition
on Jun 1, 2018 at 2:41:18 am
First you just cut to a black screen .. the use the "slide" transition.
alex ivanov
on Jun 1, 2018 at 8:07:59 pm
Paul Berk, thank you, it seems that this is what I need!
Francois Pénzes
on Jun 1, 2018 at 11:00:52 am
Hi Alex
The other way to do this is to add the Push transition to the overlap of your 2 clips.
Step 1
Step 2
You can play with the size of your black. I also noticed that the referenced clip had soft edges. Just use the Feather option but no more than an setting of 7.
Cheers !
PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
Cameras: Canon XF305 + Canon XH-A1
Blackmagic HyperDeck Studio Mini
Vegas Pro 14, User since Vegas 3.0
''When the cutting stops, the editing begins...''
alex ivanov
on Jun 1, 2018 at 8:09:54 pm
Francois Pénzes, it's not exactly what I need, following your example, my result is the clips themselves are moving, not the "obstacle" between them.
Francois Pénzes
on Jun 2, 2018 at 2:30:27 am
Hi Alex
Well that's what it does in your example...or close, it actual fact, there is a camera pan on top of the blackened effect. At least you got some options out of it.
Cheers !
