Can I create a video file in Vegas10 that is 3840 x 2160 4K?
COW Forums : VEGAS Pro
Paul Gregory
on May 26, 2018 at 6:34:16 am
I don't have a 4K video camera but I do have a lots of old photos that are of this resolution or higher as well as a 4K TV & a media player that supports this.
Is it possible to render out a video file in Vegas 10 that has 4k resolution, preferably in PAL 3840 x 2160 pixels? If so how is this done as this isn't listed in the drop down list?
Thanks in advance
Francois Pénzes
Re: Can I create a video file in Vegas10 that is 3840 x 2160 4K?
on May 26, 2018 at 9:18:56 pm
Hi Paul
I don't have V 10 anymore but I do remember it can support frame sizes up to 4096x4096.
You should be able to set it in the Video tab in Project Properties
Cheers !
PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
Cameras: Canon XF305 + Canon XH-A1
Blackmagic HyperDeck Studio Mini
Vegas Pro 14
''When the cutting stops, the editing begins...''
Paul Gregory
on May 27, 2018 at 4:36:58 am
I can set the project settings easily enough to desired resolution from the drop down list. The only setting doesn't offer PAL as an option.
Then when it comes to rendering out a clip the original codec isn't listed. I can manually change the render settings to desired resolution but the program doesn't save it. I tried rendering a 5 sec clip but all I got was a AVI file which of coarse is huge. Any other ideas?
Thanks in advance
Francois Pénzes
on May 27, 2018 at 1:36:27 pm
Hi Paul
Have you tried File - Project Properties
Input the desired frame size and frame rate (it can also be 25.000 PAL)
Don't forget to Apply before OK
I know that I still have a laptop somewhere with V10. As soon as I find it, I should be able to confirm this.
I'm going on memory here....
Cheers !
Vegas Pro 14
