Vegas can't see gh5s clips
COW Forums : VEGAS Pro
Sandra Marszałek
on May 24, 2018 at 1:41:42 pm
Hi everyone
I got some clips from gh5s.
I've tried to put them on the timeline and for those that were recorded as a slow motion everything works fine but for those in normal speed I see green screen and can hear the audio.
I can open them correctly only in VLC Media Player
Those in slow motion
Normal speed info
My spec
Vegas Pro 13
Win 8.1
That's the first time I have problems with those clips. Do I miss any new codec or something?
Mike Kujbida
Re: Vegas can't see gh5s clips
on May 24, 2018 at 1:54:16 pm
From the Vegas Creative Software forum:
Some formats it shoots will open correctly in VP13/14 but 4K 10-bit 4:2:2 AVC files weren't supported until VP15.
Sandra Marszałek
on May 24, 2018 at 1:58:07 pm
But those are normal FHD clips not 4K :/
Russ Froze
on May 31, 2018 at 9:51:10 pm
Hello, are the file extensions .mp4 or .mov. If .mov you may need to have QuickTime installed in order for Vegas to access the files.
Russ
John Rofrano
on Jun 3, 2018 at 1:31:11 pm
[Mike Kujbida] "Some formats it shoots will open correctly in VP13/14 but 4K 10-bit 4:2:2 AVC files weren't supported until VP15."
[Sandra Marszałek] "But those are normal FHD clips not 4K :/"
Yes but you are still shooting 4:2:2 AVC so maybe that is enough to make it not work? Look at the specs that you gave us in your original post:
Slow motion: (works)
Format profile: High@L5
Normal speed: (doesn't work)
Format profile: 4:2:2@L4.2
You are shooting 4:2:2@L4.2 profile so as Mike suggests this might be a case of using 2016 software with a 2018 camera. You can't expect old software like Vegas Pro 13 to always work with new cameras.
This is easy enough to figure out... I would download the trial of Vegas Pro 15 and and if it works with these files then you've found your solution (upgrade your software).
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
