Using 2 different .mp4 with frame rates of 25 and 23.5
COW Forums : VEGAS Pro
Bob Jones
on May 13, 2018 at 5:14:40 pm
Hi, I'm newish to Vegas. I have Vegas 14 Pro 64bit. I typically use it for OBS captured 60fps and my typical project settings are: HD 1080p, 59.9fps, resample mode disabled. Rendering is Sony AVC/MVC, Internet 1920x1080 60fps, and the highest bitrate 25,999,360, render quality Best.
I recently started a new project, however I discovered the main video is 25fps, and a smaller clip I want to use is 23.5fps. Is using the above settings going to mess up rendering? What would you recommend? Also the small 23.5fps clip I want to place layered within the 25fps video ie as if that small clip is appearing on a monitor in the movie. Will the difference in fps cause a problem? I am going to be timing footage to audio so I'd like everything to be precise as possible.
Thanks for any help. I tried googling but I didn't see anything specifically addressing this.
Francois Pénzes
Re: Using 2 different .mp4 with frame rates of 25 and 23.5
on May 13, 2018 at 9:14:01 pm
Hi Bob
Yup, Vegas does not like different frame rates, especially 23.5
Use something like Handbrake (it's free) to convert all your clips to the same frame rate.
Rendering should be a breeze.
Cheers !
PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
Cameras: Canon XF305 + Canon XH-A1
Blackmagic HyperDeck Studio Mini
Vegas Pro 14
''When the cutting stops, the editing begins...''
