Hi-Resolution problem
COW Forums : VEGAS Pro
John Perez
on May 3, 2018 at 2:34:30 am
I've shot "HD 21:9 Cinema" on my cell phone. The frame size is 2560 X 1080, but the image is pixillated when it should be razor-sharp, right? Below is a link to the shot. Please help....
HP Intel(R) Core i-7 CPU
950 @3.07G 3.07
RAM: 8 Gigs
64 Bit Op System
As always thanks so much to you guys...Johnny In Orlando
Francois Pénzes
Re: Hi-Resolution problem
on May 4, 2018 at 10:03:42 am
Hi John
Frame size is only one thing. Is that end result from the original file on your phone or is this from after it was dropped in Vegas ?
MediaInfo on the original file would help.
PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
Cameras: Canon XF305 + Canon XH-A1
Blackmagic HyperDeck Studio Mini
Vegas Pro 14
''When the cutting stops, the editing begins...''
John Perez
on May 4, 2018 at 11:31:40 am
Clip info: 2560 X 1080,
:38 secs duration,
24 fps
17,139 kbps
19,460 Total bitrate
Is this the file info you requested?
950 @3.07G 3.07
RAM: 8 Gigs
64 Bit Op System
John Perez
on May 4, 2018 at 11:42:19 am
Yes, that's it! The original clip plays fine in the Windows movie viewer , but get pixillated in Vegas and the exported file.
950 @3.07G 3.07
RAM: 8 Gigs
64 Bit Op System
Francois Pénzes
on May 4, 2018 at 6:57:52 pm
Hi John
Is the original clip 24 fps exactly ? or is it something like 23.(decimals) ?
That is why MediaInfo is useful, it tells you exactly what the frame rate is and a whole lot more.
Vegas doesn't like files that have a variable or weird frame rate. Try converting your file to a constant frame rate with software like Handbrake.
Cheers !
Vegas Pro 14
