Poor audio quality post-render on SVP 15 build 321
COW Forums : VEGAS Pro
John Richardson
on Mar 29, 2018 at 11:02:03 pm
I'm rendering using the MAGIX AVC/AAC MP4
Video comes out fine
Audio (voice over) has excessive hiss and what sounds like reverb. Original recording has none of this.
Changing the So4 parameter doesn't seem to make a difference.
Not using the NVIDIA support.
Any ideas on what I could try to recover the audio quality?
Graham Bernard
Re: Poor audio quality post-render on SVP 15 build 321
on Mar 30, 2018 at 5:35:44 am
[John Richardson] "I'm rendering using the MAGIX AVC/AAC MP4"
Hi John - Render to something other than that MP4 and establish if the Template isn’t fault or something deeper. What your symptoms are flagging up is as if you’d recorded the System Stereo Audio. In the meantime could you post 5 secs of pre and post Audio?
Oh yes, another thought: How are you post-Render auditioning? From the VP Timeline? Or another Player? Are you Pre and Post auditioning like-for-like?
* Grazie
Graham Bernard
on Mar 30, 2018 at 6:08:49 am
Hmm... I can't repro, I just did a render of MXF footage to MAGIX AVC/AAC MP4:
Auditioning render clip back in VP I'm not getting those symptoms - no reverb/echo or hiss.
* Grazie
John Richardson
on Mar 30, 2018 at 2:37:09 pm
Graham,
Thanks for the response! I ended up fixing this by opening a new instance of VP15, copying all the elements from the original and saving under a new name. After a reboot, I got audio that matched the original.
So kind of a false alarm - thanks for your help though!
John
