Accidently this happened. How to fix?
COW Forums : VEGAS Pro
Sandaru Dilshan
on Mar 6, 2018 at 7:45:38 am
Can you please help to fix this to normal? Also I like to know what is this feature. It happened suddenly I think when I'm dragging timeline.
http://i66.tinypic.com/op5sgi.png
Sorry for blurring. There is sensitive content.
Graham Bernard
Re: Accidently this happened. How to fix?
on Mar 6, 2018 at 8:37:21 am
If you are referring to the Zig-Zags, this indicates a changed Playback Rate. Did you want to change the Play Back Rate?
* Grazie
Sandaru Dilshan
on Mar 6, 2018 at 8:57:06 am
Thank You. Actually No. Video track somehow spited into two parts. Please check this image. I try to explain it bit clearly. http://i63.tinypic.com/29nvy29.png
I want to rejoin two parts into single path again. But there is not two tracks. Just two rows on the same track.
Graham Bernard
on Mar 6, 2018 at 9:11:38 am
[Sandaru Dilshan] "Video track somehow spited into two parts."
Understood - much clearer! You're in Expanded Track Layer Mode - I never use it . . .
Please read my responses here: https://forums.creativecow.net/readpost/24/1020721
* Grazie
Sandaru Dilshan
on Mar 6, 2018 at 11:35:02 am
You are awesome.! Thanks.
Graham Bernard
on Mar 6, 2018 at 12:06:19 pm
[Sandaru Dilshan] "You are awesome.! Thanks."
Much praise indeed! 😎
* Grazie
