Small rectangular area not working when using chroma key.
COW Forums : VEGAS Pro
Troy Bhaer
on Mar 3, 2018 at 12:03:52 am
I have what I assume is a very strnge problem, since I can't find the same issue anywhere.
When I use either Sony Chroma Key or New Blue Chroma key, there is a small rectangular area not responding, near the center of the screen. It's always in the same spot. It happens regardless of the videos being used. I cannot figure this out. Any help would be greatly appreciated.
This image I included is an example. The monitor in the video is green screened and you can see that although it works fine most everywhere, there is a small section that is still green.
Thanks again,
Troy
Steve Rhoden
Re: Small rectangular area not working when using chroma key.
on Mar 3, 2018 at 4:12:21 am
Above the preview window, there is an icon there named "Split Screen View"
un-select / disable it and you should be ok.
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Troy Bhaer
on Mar 3, 2018 at 10:41:34 pm
Steve!!! You the MAN!! I assumed that that would show up on HALF the screen, so I didn't even try it.
Thank you SO much!!! I love an easy fix. Have an awesome weekend
Steve Rhoden
on Mar 4, 2018 at 12:07:15 am
Thanks.... Glad to help!
