magix vegas pro 15 no video after render in magix prores hq
COW Forums : VEGAS Pro
Eric Sanchez
on Feb 24, 2018 at 12:51:47 am
so ive upgraded my laptop and decided to upgrade to the latest greatest vegas since i was using 12 and 13...
anyways, i went to render my project and tried to save in magix prores hq and it didnt save the video portion..
needless to say the video track wasnt muted or anything of that nature. is there a specific way to save in prores..
i usually would save in sony avc as a mp4 blah blah but since prores is all the hype these days i figured id save it as such.
anyways ...hope someone can help me.
John Rofrano
Re: magix vegas pro 15 no video after render in magix prores hq
on Feb 24, 2018 at 11:18:09 pm
[Eric Sanchez] "i went to render my project and tried to save in magix prores hq and it didnt save the video portion.."
What are you basing this on? Did you try and view it on your PC after the render? What did you use to play it back. Apple ProRes is a QuickTime format. Do you have Apple QuickTime installed? If not, you won't see any video because the ProRes codec comes with QuickTime.
[Eric Sanchez] "i usually would save in sony avc as a mp4 blah blah but since prores is all the hype these days i figured id save it as such."
Apple ProRes is not "hype". It has been the defacto industry standard on the Mac for many, many years for delivery to broadcast, film, etc. but it doesn't play well with Windows PC's so if you don't need to use it to submit your work, I would avoid it. It's not a native format for the PC. MAGIX added it to Vegas Pro to be Mac compatible because most Post houses are Mac based and require ProRes for submission.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
Eric Sanchez
on Feb 26, 2018 at 8:17:52 pm
yea fter render i attempted to play it to see how it looked etc, and i only played the audio... i also did not try it in quicktime... so that may have been a issue but yes moving forward i will be sure if i save in prores to use quicktime to preview... also in your opinion what is the highest quality to save videos in. i film music videos amongst many other things but primarily music videos. which usually go on youtube but occasionally they may need it for television. any reccomendations ?
John Rofrano
on Feb 26, 2018 at 9:19:15 pm
Are you working in HD or 4K? We use to use Sony MXF HD422 1080-60i 50Mbps to send HD to NTSC broadcast. It had plenty of quality and you can create your MP4 files for YouTube from it.
~jr
Eric Sanchez
on Feb 26, 2018 at 10:58:43 pm
mostly 1080p hd...
