VP 15 Build 311 Out. DVD Arc Also Updated
COW Forums : VEGAS Pro
Mike Carlo
on Feb 20, 2018 at 12:49:51 am
Use Vegas DLM and Vegas 15 has build 311, and DVD Arc is build 84. I cannot find release notes.
Graham Bernard
Re: VP 15 Build 311 Out. DVD Arc Also Updated
on Feb 20, 2018 at 4:39:14 am
[Mike Carlo] "Use Vegas DLM and Vegas 15 has build 311, and DVD Arc is build 84. I cannot find release notes."
Nothing on the Official Vegas site. I’m holding-off until I read/hear an official MAGIX qualification of this being correct.
* Grazie
Mike Carlo
on Feb 20, 2018 at 6:43:52 pm
Dear community,
As some of you already noticed, we released a new patch for VEGAS Pro 15 earlier today!
This patch addresses many issues that were keeping some of you from using the new So4compoundplug, and it will make that much more stable for you. There are a few other fixes and a few new/imroved features as well. The list below gives you specifics of Update #3. We look forward to your feedback in our general discussion thread.
You can download the build 311 now at: http://rdir.magix.net/?page=5LUFX128OV3K
Here are the patch notes for this update:
New Features
Updated support for RED Epic Dragon, Raven, Scarlet, and Weapon files
The LUT OFX filter now taps into graphics card GPU for faster performance
Reduce memory footprint of so4compoundplug and improve load performance for very large projects
Preview framerate during crossfades when using the So4 Compound Reader has been improved
Bug Fixes
Stereo tracks from certain file types which were improperly imported as multiple mono tracks are now properly imported to stereo tracks
Audio from Xiaomi Yi 4k or greater files now plays correctly with so4compoundplug
DJI Spark files with variable frame rate files are now properly supported
Fixed an issue with not being able to delete media file used in Vegas Project even after closing project
Video from the Samsung Galaxy S8 is now properly decoded through Intel QSV decoder
Video event buttons no longer disappear when entering expanded edit mode or expanded track mode
The Active Take Information (and other event text items) no longer react to the Button Highlight Color preference
The audio in ProRess 422 files created through Convergent Design hardware is now handled properly
XAVC now properly shows up as an option in the Prerender Video format list
The Render As dialog's Name field no longer locks after rending to a Panasonic P2 file
Fixed a crash that could occur on exiting the software when the project uses interlaced files and you close it without saving
AVC files created by MP4 Creator no longer crash when not using the QSV decoder
Audio from HEVC video shot with the GoPro HERO6 is now properly supported
Improved stability of the Defocus and Starburst effects when running with an AMD GPU
Video created with unusual aspect ratios are now properly handled
AVC/PCM audio files no longer distort during playback
AVC/MOV 29.97 files from the iPhone 6s are now handled properly
The LUT FIlter is now handled properly in 8bit pixel format projects with GPU acceleration of video processing set to off
The Border plug-in now properly recognizes when a frame size has been changed with GPU active
Video form the Samsung Galaxy S8 is now properly decoded through Intel QSV decoder
It is now possible to render 10-bit HEVC files using SkyLake or older processors with QSV
Did you miss an update? Have a look at our previous patch notes!
Setiawan Kartawidjaja
on Feb 20, 2018 at 11:07:59 pm
Reference link:
https://www.vegascreativesoftware.info/us/forum/vegas-pro-15-update-3-build...
Setiawan
Chungs Video Production
Bandung, Indonesia
