Vegas Pro Video FX in Video Preview Syncing Problem
COW Forums : VEGAS Pro
Brayl Majam
on Feb 19, 2018 at 9:48:28 pm
Hi guys,
Just as the title says, whenever i drag a video effect to my clip and adjust its settings , the video preview doesn't automatically show the settings. But if I click the Pan/Crop tab or exit the entire Video Event FX window then it shows
the changes.
UPDATE: I just solved it myself.. If anyone else has this problem then I suggest that you go to Preferences>Video>Turn off GPU acceleration of video processing.
Jorma Nippala
Re: Vegas Pro Video FX in Video Preview Syncing Problem
on Feb 20, 2018 at 9:43:01 am
Read also https://www.vegascreativesoftware.info/us/forum/solved-issue-with-effects--...
John Rofrano
on Feb 20, 2018 at 3:13:00 pm
[Brayl Majam] "UPDATE: I just solved it myself.. If anyone else has this problem then I suggest that you go to Preferences>Video>Turn off GPU acceleration of video processing."
I just want to thank you for getting back to the community with the solution. Too often people come here and post a question, figure it out for themselves, and never return. It's thoughtful members like you that make the COW a great community to be part of. This will definitely help someone in the future.
Yea, GPU support is unfortunately at the root of far too many preview problems. The rule of thumb is... if something looks wacky... turn of the GPU and see if it fixes it.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
