Double File Size??
COW Forums : VEGAS Pro
Gary Markman
Double File Size??
on Feb 17, 2018 at 4:52:06 pm
I normally use Vegas 7 to render to MPEG 2 on an XP Pro machine and then use DVD Architect to make DVD's, obviously that is becoming more and more problematic. I have a 10 machine with Vegas Pro 13 on it but I am running into an issue making the same MPEG 2 files. A file rendered in 13 and put into Architect shows up at double the file size it says it is. In file explorer it may say 2gb for example but Architect says it is 4gb. I can re render the same file using my settings in Vegas 7 and it comes out correct. I have meticulously copied the settings from 7 to 13 for video settings. Ive checked and re checked and re checked again, the settings are the same. My guess is that13 is doing something funny with the audio that creates the same size separate file as the video, again, just a guess....
Any thoughts? Do I have something in 13 checked or unchecked that is creating this ghost file???
Thank you in advance.
Gary Markman
Re: Double File Size??
on Feb 26, 2018 at 9:05:31 pm
bump
