Can I combine .mov with .mp4 on the same timeline without loss of quality?
COW Forums : VEGAS Pro
Lindsay Thompson
on Feb 15, 2018 at 2:41:41 am
Am I going to have issues merging two different formats together (.mov and .mp4) on the timeline, everything else being the same (fps and size)?
I just realized that while I made sure that I used the same fps in shooting my video from both my drone (interchangeable formats, which I chose .mp4) and from my camera, I just now realized they are two different formats! Man...just when I thought I was getting the hang of all of this.
Thanks in advance!
Sony Vegas Pro 14 Noob
Wayne Waag
Re: Can I combine .mov with .mp4 on the same timeline without loss of quality?
on Feb 15, 2018 at 4:36:10 am
Yes you can--no problem. MOV's and MP4's are just containers. The important thing is the format of the video stream (e.g. avc) which in your case is the same. For V14, it shouldn't be a problem since it should use the same decoder. Try it.
wwaag
Nigel O'Neill
on Feb 15, 2018 at 9:07:05 am
Vegas can sometimes just show the MOV's as black preview after a while or if there are too many MOV files. I use Qwinff to convert all my MOV files to MP4.
My system specs: Intel i7 7700k 4.20 GHz, GTX570, 16GB RAM, Gigabye Z170 HD3, Vegas Pro 12 (x64), Windows 10 x64 Pro, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
Lindsay Thompson
on Feb 17, 2018 at 5:20:55 am
I will look into that. I am not having an issue at this time. But it is sure nice to have the answer if I do end up having he problem. Thank you!!
Lindsay Thompson
on Feb 17, 2018 at 5:19:43 am
Thank you for answering me so quickly!
