vcr to Vegas 12
COW Forums : VEGAS Pro
Jack Gill
vcr to Vegas 12
on Feb 12, 2018 at 1:07:19 am
Trying to feed a vcr into Vegas 12. have a Canopus ADVC100 between the vcr and my computer. The Canopus is attached to my computer via Firewire. Vegas is not recognizing the vcr. Help, please.
Jack
Francois Pénzes
Re: vcr to Vegas 12
on Feb 12, 2018 at 1:57:23 am
Hi Jack
First thing to check, is your OS recognizing the Canopus 'cuz if the OS is not seeing the Canopus then no software will.
When your done checking, please post machine and OS specs.
Cheers !
PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
Cameras: Canon XF305 + Canon XH-A1
Blackmagic HyperDeck Studio Mini
''When the cutting stops, the editing begins...''
Jack Gill
Re: vcr to Vegas 12
on Feb 12, 2018 at 2:22:37 am
Francois,
I'm not much of a techie. How can I tell if my computer is seeing the Canopus?
I have a custom PC with an ASUS P7P5SD (green) motherboard, an Intel quad CPU,
Francois Pénzes
Re: vcr to Vegas 12
on Feb 12, 2018 at 3:18:06 am
Hi Jack
I will assume that your are running Win 10.
Go to Start/Settings/Devices and under Other Devices your Canopus should be showing.
Cheers !
Jack Gill
Re: vcr to Vegas 12
on Feb 12, 2018 at 3:42:36 am
I am running w 7. Does that make a difference. Following your directions I couldn't get to where I wanted to go.
Jack
Francois Pénzes
Re: vcr to Vegas 12
on Feb 13, 2018 at 12:57:22 am
Hi Jack
This is definitely not the best explanatory video but it will tell how to get to device manager in Win 7.
Cheers !
Jack Gill
Re: vcr to Vegas 12
on Feb 13, 2018 at 3:02:47 am
Ok. Here is where I am.
1. Grass Valley no longer supports my canopus 110
2. In my Device Manager I have an active firewire
3. A release from Grass Valley declares that the 110 has been tested and absolutely works with W 7
4. Perhaps I don't understand how to make the connection to my Vegas 12.
Jack
Francois Pénzes
Re: vcr to Vegas 12
on Feb 13, 2018 at 11:24:10 am
Hi Jack
The problem seems to be with the way your Canopus communicates with your computer. Make sure that the hook-ups are correct. I have included a link to a user manual for your Canopus in case you (or any others coming here) need to do some troubleshooting. Have a good read, even the best of us miss something...sometimes. (Don't forget about those pesky hard to read dip switches, page 16)
https://www.bhphotovideo.com/lit_files/71386.pdf
Once you will have solved your communication problem with your computer, Vegas should recognize it straight off.
P.S.: When you get it working (and it will) please come back and let us know how you did it, so that the next person can benefit.
Cheers !
John Rofrano
Re: vcr to Vegas 12
on Feb 17, 2018 at 3:12:22 am
I thought I had read that Windows 7 has a problem with some Firewire devices requiring that you use the "Legacy" Firewire drivers. Here is an article about it:
Changing to the Legacy IEEE-1394 (Firewire) Driver in Windows 7
It might have something to do with it.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
Jack Gill
Re: vcr to Vegas 12
on Feb 17, 2018 at 4:24:54 am
John, Thanks so much for your input. I am always delighted when you jump in to help. Jacck
Jack Gill
Re: vcr to Vegas 12
on Feb 19, 2018 at 7:36:22 pm
John,
Followed directions for loading legacy, but nothing so far. Perhaps I don't understand how to make the connection to Vegas 12.
Jack Gill
John Rofrano
Re: vcr to Vegas 12
on Feb 19, 2018 at 9:18:56 pm
[Jack Gill] "Perhaps I don't understand how to make the connection to Vegas 12"
Well the first thing you need to do is make sure that Windows 7 can connect to your device. I have the Canopus ADVC300 but the ADVC100 should look very similar.
In your Windows 7 Device Manager, under Imaging devices do you have a device called AV/C Tape Recorder/Player?
If you don't see this device, then Windows 7 can't see your Canopus ADVC100 and Vegas Pro will never see it. So let's start there.
~jr
Jack Gill
Re: vcr to Vegas 12
on Feb 19, 2018 at 10:45:13 pm
I've got it!
Jack
Jack Gill
Re: vcr to Vegas 12
on Feb 20, 2018 at 5:23:14 am
John, I noticed that I see AV/C Tape Recorder/Player only when my Canopus is turned on.
Jack
John Rofrano
Re: vcr to Vegas 12
on Feb 20, 2018 at 12:23:26 pm
[Jack Gill] "I noticed that I see AV/C Tape Recorder/Player only when my Canopus is turned on."
Great! Yes, the device is a "real" device so if it's turned off Windows won't see it. That's great news, that means that Windows 7 can see your ADVC100.
Next, with the ADVC100 turned on, in Vegas Pro 12 when you go to File | Capture Video... to capture your tapes, do you see this dialog box pop up and do your select DV? (you should)
That should bring up the VidCap program that captures from DV tape.
And you should see the window above. Do you get that?
~jr
Jack Gill
Re: vcr to Vegas 12
on Feb 20, 2018 at 3:14:05 pm
When I get to the vidcap screen it references Manycam, which I have on my computer. I have a blue box that says preview is turned off, even tho I have it turned on. Boy, here's where I start to get real confused!!
John Rofrano
Re: vcr to Vegas 12
on Feb 20, 2018 at 3:39:37 pm
[Jack Gill] "When I get to the vidcap screen it references Manycam, which I have on my computer. "
I'm guessing that this is your problem right there.
Open the Video menu from the top menu bar and select your Canopus ADVC100. That should make it talk to the Canopus device instead of Manycam and allow you to capture your tapes.
~jr
Jack Gill
Re: vcr to Vegas 12
on Feb 20, 2018 at 6:32:31 pm
BINGO!!!!
That did it. Now recording. Thanks so ever much John and the others who pitched in.
Jack Gill
Francois Blawat
Re: vcr to Vegas 12
on Feb 20, 2018 at 9:40:06 pm
Thank you John Rofran for referring to that Article about using Legacy Drivers under Windows 7. I have an ADVC-55 and I was having issues. These forums are great for resources and help.
FixitMad
John Rofrano
Re: vcr to Vegas 12
on Feb 21, 2018 at 11:18:10 pm
[Francois Blawat] "Thank you John Rofrano for referring to that Article about using Legacy Drivers under Windows 7"
Great! I'm glad that helped. I have a bunch of tapes that I have to sit down and capture so I'm about to go through the same thing with my ADVC300.
~jr
John Rofrano
Re: vcr to Vegas 12
on Feb 21, 2018 at 11:16:48 pm
[Jack Gill] "BINGO!!!!"
Ding! Ding! Ding! We have a WINNER! 😃
You are very welcome... Glad you got it working.
~jr
