Vegas hits 100% CPU and quits responding
COW Forums : VEGAS Pro
Donald Froneberger
on Feb 10, 2018 at 6:21:51 pm
Im new to vegas pro and can't figure out why i can't go 5 seconds without it crashing. Using a Dell XPS with i7. I've messed with all the setting on the preview and nothing changes. every time i make a simple change or anything i have to save it because it will soon crash.
i finally got my first video done. very basic. and i have tried a few times to render it and none of them have made it past 9%
what is my issue here!?
Steve Rhoden
Re: Vegas hits 100% CPU and quits responding
on Feb 13, 2018 at 8:36:01 pm
Something you have installed is conflicting with Vegas!
Also you haven't mentioned which version of Vegas you are using.
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Sam rosenthal
on Feb 15, 2018 at 3:35:14 am
Does anyone have advice for how to "set up Vegas" so it crashes less? are there places to assign how much Ram is used, how much is retained in cache, etc etc? I often wonder if Vegas crashes because it's storing too much junk. Also, is there a place where you can clear out past edit memory? Or limit how much of that junk it holds onto?
Is there a place to read BEST PRACTICES for using Vegas?
PRO12 Build 770
Running in Windows 7 on a Bootcamped Mac
Nigel O'Neill
on Feb 15, 2018 at 9:08:37 am
Disable GPU acceleration in preview and the render template and stability shall return
My system specs: Intel i7 7700k 4.20 GHz, GTX570, 16GB RAM, Gigabye Z170 HD3, Vegas Pro 12 (x64), Windows 10 x64 Pro, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
