Rendering a .mov file in DNxHD (or ProRes) to use in ProTools 2018
COW Forums : VEGAS Pro
David Nazario
on Feb 9, 2018 at 1:50:52 am
Hey everyone!
First time posting here. I'm having a problem where whenever I try to render a .mov file using Avid's DNxHD codec, Vegas Pro 14 completes rendering in less than a second (the video is one minute long) and doesn't actually rending a video file. The folder is empty.
ProRes 422 works but when I try to import it into the ProTools project the application just freezes up and crashes.
I tried repairing Avid's DNxHD codec by reinstalling it but that didn't work at all. I'm really at a loss here and it's been a struggle to find a good video format that is compatible with ProTools that doesn't cause playback issues.
Any help with this would be greatly appreciated!
-Dave N.
Ole Kristiansen
Re: Rendering a .mov file in DNxHD (or ProRes) to use in ProTools 2018
on Feb 9, 2018 at 3:02:56 pm
What are your render settings in Vegas Pro 14 - What drive are you render to ?
What are the specs of your footage ?
David Nazario
on Feb 9, 2018 at 8:34:19 pm
Ok, so your question about what drive I render to definitely helped. I can now render a video in DNxHD by having it render to my main C-drive. The only problem now is that when I try to import my video into ProTools, it still freezes up and crashes. So, here are my render settings for the video in DNxHD:
Frame size: High Definition (1920x1080)
Frame rate: 29.970000
Field order: Upper field first
Pixel aspect ratio: 1.000
Video format: Avid DNxHD Codec
Compressed depth: 32 bpp color
Quality: High 100%
Audio:
None/Unchecked
Avid DNxHD Codec Settings:
Color Levels: 709
Alpha: None
Resolutions: 1080p/29.97 DNxHD 100 8-bit
Rendered out, it plays just fine in Quicktime player but when I try to bring the video into ProTools everything goes haywire.
Ole Kristiansen
on Feb 9, 2018 at 9:25:27 pm
Hmm, is your footage progressive or interlaced ?
If your footage is progressive - set Field order: None
David Nazario
on Feb 9, 2018 at 9:45:37 pm
Yeah, I thought about that after I posted. Changed it to None (Progressive) and still got the same result. Now I'm starting to think this is a problem with ProTools which seems weird cause DNxHD is Avid's codec so it should work just fine.
Ole Kristiansen
on Feb 9, 2018 at 9:51:18 pm
http://avid.force.com/pkb/articles/en_US/Compatibility/Avid-Qualified-video...
Ole Kristiansen
on Feb 9, 2018 at 9:54:41 pm
Maybe try with Sony XAVC Long GOP ?
David Nazario
on Feb 9, 2018 at 10:28:12 pm
I think I found the issue.
http://duc.avid.com/showthread.php?t=397034
So it probably isn't the render that's the problem but a Windows-only issue with the new update of ProTools 2018. Uninstalling and reinstalling now to see if that fixes my problem. Fingers crossed!
Ole Kristiansen
on Feb 9, 2018 at 10:39:41 pm
Yes, fingers crossed :)
David Nazario
on Feb 9, 2018 at 11:02:17 pm
Yup! That was the fix! Just uninstalling and reinstalling PT 2018. Man, that was an annoying ride lol.
Thanks for replying by the way! Appreciate the help!
