Vegas 15 crashing.... need to save work
COW Forums : VEGAS Pro
Martin Phillips
on Feb 5, 2018 at 8:22:27 pm
Hi, Ive been having some nightmares with stability on vegas pro 15, i am in contact with support - but in the mean time i don't want to have to re do the 2 days work I've just done on the initial cut of a project.
I upgraded from Veras pro 12 with is on the same Pc and is as solid as a rock.......
The footage is all HD, some 50fps and some 25fps.... i was thinking of just rendering out the timeline as one and dropping it into vegas 12.... what would be the best template/setting to use?, or is there another way.
Regards Martin
Paul Berk
Re: Vegas 15 crashing.... need to save work
on Feb 6, 2018 at 12:56:52 am
HD Mxf files would be a good choice. They are nearly loseless.
