Editing 4K iPhone .MOV files in Vegas Pro 13
COW Forums : VEGAS Pro
Nick Frankiewitz
on Jan 27, 2018 at 5:00:09 pm
Whenever I try to import 4K iPhone .MOV files into the timeline in Vegas Pro 13, only the audio shows up. I have searched and searched, and can't find any really solid information about this. Vegas Pro 13 doesn't have any problems at all with 4K footage from my Sony FDR AX100, so I know it can handle 4K footage. But this iPhone footage has me baffled.
Here are the video specs of a sample 4K video clip that I'm trying to import:
Format/Info: High Efficiency Video Coding (HEVC)
Format profile: Main@L5.1@High
Codec ID: hvc1
Codec ID/Info: HEVC
Bit rate: 53.5 Mb/s
Width: 3,840 pixels
Height: 2,160 pixels
Display aspect ratio: 16:9
Frame rate mode: Variable
Frame rate : 60.000 FPS
Minimum frame rate: 54.545 FPS
Maximum frame rate: 60.000 FPS
Color space: YUV
Chroma subsampling: 4:2:0
Bit depth: 8 bits
Bits/(Pixel*Frame): 0.107
Title: Core Media Video
Color range: Limited
Color primaries: BT.709
Transfer characteristics: BT.709
Matrix coefficients: BT.709
Ole Kristiansen
Re: Editing 4K iPhone .MOV files in Vegas Pro 13
on Jan 27, 2018 at 5:41:11 pm
It is because nle doesn't like variable framerate - your phone use variable framerate for expouser !
You have to convert your footage to constant framerate before you can use them in Sony Vegas !
Ole Kristiansen
on Jan 27, 2018 at 6:06:20 pm
Also the hevc h.265 maybe is a problem for Sony Vegas Pro 13 - I don't now but try with Handbrake to convert your hevc h.265 to x.264 with constant framerate !
Maybe buy and install the Filmic Pro app on your phone - then you can use your phone like a video camera and set it to constant framerate !
Nick Frankiewitz
on Jan 27, 2018 at 8:13:01 pm
I never used Handbrake before, so I downloaded it and gave it a try. I converted using the H.264 codec at 30 FPS with the same frame width & height (3840x2160) with a constant quality of 20 to an MP4 file.
And it worked like a charm! Vegas now allows me to import the video files.
Many thanks Ole!
Ole Kristiansen
on Jan 27, 2018 at 10:27:04 pm
You are welcome Nick !
John Rofrano
on Jan 28, 2018 at 12:21:40 am
[Ole Kristiansen] "Maybe buy and install the Filmic Pro app on your phone - then you can use your phone like a video camera and set it to constant framerate !"
+1
If you are shooting video with your iPhone I highly recommend getting Filmic Pro. It will give you a lot more control and is worth every penny.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
