image rotation
COW Forums : VEGAS Pro
Joost Zeeveneegelbeek
image rotation
on Jan 25, 2018 at 6:26:14 pm
Is there a way in which you can place the centre of a rotation somewhere else than in the middel of the screen? I have placed a cropped image at the side of the frame. When I rotate the image 180 degrees it is at the opposite side of the frame. I would like to have the cropped image rotate in place. Now I just fill in several intermediate positions. But that takes a lot of work to get right. Is there a simpler way?
john bolton
Re: image rotation
on Jan 26, 2018 at 8:16:17 am
Move the image using Track Motion to the part of the screen where you want it positioned.
John Rofrano
Re: image rotation
on Jan 26, 2018 at 12:50:47 pm
[john bolton] "Move the image using Track Motion to the part of the screen where you want it positioned."
Actually you can also change the pivot point using 3D Track Motion (which is why it is 3D)
Here is an old tutorial of mine showing you how to use 3D Track Motion Pivot
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
