WAV files issues
COW Forums : VEGAS Pro
Ross Stark
WAV files issues
on Jan 25, 2018 at 5:03:54 am
I'm trying to open a wav file in Vegas 13 it says in the explorer tab "stream attributes could not be determined" and I cannot drop the file in the timeline.
Help!!!
Graham Bernard
Re: WAV files issues
on Jan 25, 2018 at 11:11:54 am
[Ross Stark] "Help!!!"Well, Ross, help us. Use MediaInfo and give us the detail of the Audio.
* Grazie
Ross Stark
on Jan 25, 2018 at 1:35:15 pm
Thanks Graham. Here's what I'm seeing:
Format : Wave
File size : 27.1 MiB
Duration : 9 min 51 s
Overall bit rate mode : Constant
Overall bit rate : 384 kb/s
Producer : Dalet Digital Media Systems
Description : \\arsenic\English$\Audio\00a71495[tempOverride].wav
Encoded date : 2017:11:07 18:42:31
Encoding settings : A=MPEG1L2,F=48000,B=384,W=16,M=STEREO
Producer_Reference : FRDMS000000000000
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Codec ID : 50
Bit rate mode : Constant
Bit rate : 384 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Compression mode : Lossy
Stream size : 27.1 MiB (100%)
Graham Bernard
on Jan 25, 2018 at 2:43:28 pm
Have you tried to match your Project Settings to the Media? Try that, and see if you can force a “match” then interrogate the Audio.
I can think of two reasons:
1) You don’t have the CODEC. Interrogate MediaInfo and see if the audio CODEC is apparent on your PC.
2) The wav is corrupt.
Can you play it on any player on your PC?
Interesting.
* Grazie
Ross Stark
on Jan 25, 2018 at 3:11:06 pm
I have played it on the stock Windows10 media player (Groove?).
I'll give both of those options you mentioned a try later when I'm back at my desk. I'll also update for anyone else to reference later.
Thank you for your time!
John Rofrano
on Jan 25, 2018 at 3:36:11 pm
[Ross Stark] "Format : MPEG Audio"
I'm guessing that this is your problem. While compression is allowed in the WAV file spec, it is almost never used and Vegas Pro probably expects the file to contain uncompressed linear pulse-code modulation (LPCM) format. Try renaming the file with an .mpg extensions and see if that helps because the file contains MPEG audio not PCM. BTW, I've never encountered a WAV file that wasn't PCM.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
