Brighten really dark video
COW Forums : VEGAS Pro
Tobin Bell
on Jan 22, 2018 at 1:55:59 pm
Hey there,
I have a very dark video and I'm out of ideas how could this be brightening in Vegas Pro. My best result was around "Brightness and Contrast" but the outcome was densely greased with red (and other colors) noises, which I was then unable to reduce at all.
I attached a small part of the video here. Do you have any idea how to achieve the best result?
12092_aa.avi.zip
Thanks for any help!
Graham Bernard
Re: Brighten really dark video
on Jan 22, 2018 at 3:50:53 pm
[Tobin Bell] " My best result was around "Brightness and Contrast""
STEP AWAY FROM THE B&C FX!!
OK, here's my attempt:
Left side is corrected. Right side is nothing.
* Grazie
Tobin Bell
on Jan 22, 2018 at 5:28:37 pm
This seems quite good for my needs!
Could you elaborate what did you set in the rest of the used plugins? I mean which noise filter settings used in Neat, which ColorFast and Corrector presets, etc.
Graham Bernard
on Jan 22, 2018 at 5:42:05 pm
[Tobin Bell] "Could you elaborate what did you set in the rest of the used plugins?"
Here's the Veg file for you to interrogate!
12094_tobinliftingdarks1a.zip
* Grazie
Tobin Bell
on Jan 23, 2018 at 1:00:56 pm
I was unsuccess to obtain NewBlue's ColorFast 2 plugin so unfortunately the *.veg file failed to load every filters after the Neat Video one. Thank you anyway, Graham.
Graham Bernard
on Jan 23, 2018 at 3:52:30 pm
[Tobin Bell] "Thank you anyway, Graham."
Well, you can get a long way forward with the others. Just delete the CF2 node. But you can see the settings for NV and the rest? Yes? Why can’t you get the CF2?
* Grazie
Tobin Bell
on Jan 23, 2018 at 4:42:06 pm
Well, because the price $99 is a bit expensive for me at the moment and I couldn't find any other method to obtain it.
The .veg stops loading halfway at the point when it doesn't find the CF2 plugin. From there, it doesn't load any further plugin, so I see only the first two FX in the "Video Event FX" window: the "Levels" and the "Neat Video" (Neat is set to use the "Default" filter settings (60% lumi, 100% chrom, 0% sharp))
Graham Bernard
on Jan 23, 2018 at 5:24:24 pm
[Tobin Bell] "Well, because the price $99 is a bit expensive for me at the moment and I couldn't find any other method to obtain it."
Sure, I understand. However CF has got me back some great footage, when you can afford it do try. Does NB run a demo for you to use? What I could do, if you’re still interested, is I could delete the CF Plug here, and create a new VEG. Are you interested in that?
* Grazie
Tobin Bell
on Jan 23, 2018 at 6:50:34 pm
Yes, it would be nice if you could remove the CF2 part.
I have the basic ColorFast NB plugin however, I don't know if it's good to replace with.
Graham Bernard
on Jan 23, 2018 at 7:47:03 pm
[Tobin Bell] "Yes, it would be nice if you could remove the CF2 part. "
Sure. On the case. Give me 5 minutes.
* Grazie
Graham Bernard
on Jan 23, 2018 at 7:54:45 pm
No ColorFast2
OK, now remember you WILL need to adjust the other plugs to compensate - yeah?
* Grazie
Tobin Bell
on Jan 23, 2018 at 8:48:05 pm
Thank you so much, Graham, this works fluently. I'm already on the tweaking. ☺
Thank you for the generous help & assistance!
