Aspect Ratios
COW Forums : VEGAS Pro
John Perez
Aspect Ratios
on Jan 13, 2018 at 5:06:30 pm
I see films with 2.4 to one aspect ratio. What format are they using, what codecs?
HP Intel(R) Core i-7 CPU
950 @3.07G 3.07
RAM: 8 Gigs
64 Bit Op System
As always thanks so much to you guys...Johnny In Orlando
Francois Pénzes
Re: Aspect Ratios
on Jan 14, 2018 at 3:10:55 am
Hi John
I'm at a bit of a loss to understand why you would want to take this road. The 2.40 to 1 format (actually 2.39) was originally developed in order to make full usage of the frame on 4-perf film. It is shot with an anamorphic lens and when projected the process is reversed.
Now, if you want that ''Panavision'' look, change your parameters to 1.2121 (File/Properties/Video/Pixel Aspect Ratio)
Don't forget to shoot and frame accordingly.
Cheers !
PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
Cameras: Canon XF305 + Canon XH-A1
Blackmagic HyperDeck Studio Mini
''When the cutting stops, the editing begins...''
