Trying to Turn a Vertical Video for my Horizontal Video
COW Forums : VEGAS Pro
John Lee
on Jan 9, 2018 at 10:32:31 pm
I have a Vegas project that is 1920x1080. I need to insert some video taken by an iPhone which was unfortunately filmed vertically. I've watched YT videos to make it horizontal, but all it does is turn it somewhat landscape, but nowhere near filling the screen (even when I play with the pan tool).
Any idea what I'm doing wrong? I de-selected the lock aspect ratio, but I still have a problem. The original film is 320 width x 568.
Thanks for any advice.
Marco Baer
Re: Trying to Turn a Vertical Video for my Horizontal Video
on Jan 9, 2018 at 10:50:40 pm
Set your Vegas project properties (the frame size) to same size as your video is.
John Lee
on Jan 10, 2018 at 7:38:17 pm
This project has other videos that are 1920x1080, so I need to keep the project settings as such.
If something is filmed vertically (320 x 568, in this case), is there a way to resize the video so that it fills a screen for a project that is 1920 x 1080?
Marco Baer
on Jan 10, 2018 at 8:50:41 pm
Then you need to use Pan/Crop.
Right-click into the editing area of the Pan/Crop window and select "Match Output Aspect" while "Stretch to Frame Size" is unchecked.
John Lee
on Jan 10, 2018 at 9:57:21 pm
Thank you for the reply, but I don't get it. I went to the clip, right clicked and selected "Video Event Pan/Crop", and the window popped up.
But nothing happens when I right click that pop-up window. I can't seem to find "match output aspect" or "stretch to frame size".
John Lee
on Jan 10, 2018 at 10:09:22 pm
Also this is a video, not an image. Does that make a difference?
Marco Baer
on Jan 10, 2018 at 10:12:42 pm
No, there is no difference. It works fine with video.
Don't right-click the clip. Open Pan/Crop for that clip and right-click the frame inside the Pan/Crop window.
John Lee
on Jan 10, 2018 at 10:17:14 pm
I tried right clicking inside the pan/crop pop-up window, but no dialogue box shows up. Instead, the cursor turns into a magnifying glass and the image shrinks.
What am I doing wrong?
Marco Baer
on Jan 10, 2018 at 10:25:17 pm
This is what right-clicking the video frame inside of Pan/Crop does here:
John Lee
on Jan 10, 2018 at 10:47:57 pm
Thank you. The magnifying tool was on. Got it now.
