Masking query
COW Forums : VEGAS Pro
David Hague
Masking query
on Dec 29, 2017 at 6:10:09 am
In Photoshop, if you have two images - one on top of the other - and you want to blend between the two so they appear side by side like below, it is relatively easy. But doing it in Vegas with video has me flummoxed! Any clues please? Many thank you's ☺
john bolton
Re: Masking query
on Dec 29, 2017 at 8:31:52 am
Place the two pieces of media one above the other on the timeline ///
You use the Event/Pan Crop selection and select the Mask Tick box at the bottom left. Then draw around the section you want to see and then select Feather Out or In to soften the centre edges. Do the same for the other timeline media. You can re-position the media using Track Motion.. Hope this helps
john bolton
Re: Masking query
on Jan 1, 2018 at 3:59:10 pm
Did you solve the problem?.. I can send you a configured Veg if you need it..
David Hague
Re: Masking query
on Jan 2, 2018 at 2:46:46 am
It did; thank you so much! But I would appreciate a VEG too if it is not too much trouble?
vbthedog@gmail.com
David
David
john bolton
Re: Masking query
on Jan 2, 2018 at 8:38:01 am
Hello David
Just a quick bit of merging. Nothing special but just in case you need to see.
https://www.dropbox.com/s/bj25q47o842x7vf/merge.zip?dl=0
Thanks for letting us know you solved your query. it is always nice to get feedback as other users may not know whether the solutions work or not..
Regards
David Hague
Re: Masking query
on Jan 3, 2018 at 3:25:04 am
Thank you John... that clears it up even more :)
David
john bolton
Re: Masking query
on Jan 3, 2018 at 8:18:17 am
Glad it helped... Regards
