MVP 15 won't run .net issue?
COW Forums : VEGAS Pro
Scott Francis
on Dec 21, 2017 at 5:14:31 pm
Hey All,
Just downloaded and installed my MVP upgrade. Went to run and now I get this:
Failed to initialize the common language runtime engine. Please install the .NET Framework (download is available from Windows Update).
I am running Windows 10 Pro, everything is up to date Windows wise and I turned everything on for netframework 3.5 and 4.7 in my "turn windows features on and off."
Any ideas?
Xavier (Scott) Francis
Mind's Eye Audio/Video Productions
Gabriel Meono
Re: MVP 15 won't run .net issue?
on Feb 28, 2018 at 6:22:43 am
Same issue here, have you solved this?
Vegas 13 and 14 work perfectly, and Vegas 15 refuses to work.
Scott Francis
on Feb 28, 2018 at 10:50:36 am
I did get it resolved, but not sure how. I believe I found some resources by Googling....
Sorry I can recall. I THINK I had to adjust some Windows 10 settings
Good luck!
Francois Pénzes
on Feb 28, 2018 at 11:39:54 am
Hi Scott
Have you tried this fix from the Vegas forum ?
https://www.vegascreativesoftware.info/us/forum/vegas-pro-15-build-177-gene...
Here's hoping that it'll help.
Cheers !
PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
Cameras: Canon XF305 + Canon XH-A1
Blackmagic HyperDeck Studio Mini
''When the cutting stops, the editing begins...''
Scott Francis
on Feb 28, 2018 at 11:54:44 am
YES!!!
That was the fix I used. I have had to reset my VST plugin settings numerous times for transport issues to, so this seems to help.
Gabriel Meono
on Feb 28, 2018 at 5:45:46 pm
I'm my case I had to rename "C:\Program Files\Common Files\OFX\Plugins" folder.
It seems Real Smart Motion Blur (RSMB5OFX) was causing the crashes.
Thanks for posting that thread with the workarounds!
