Create Slideshow in 4K
COW Forums : VEGAS Pro
Paul Gregory
on Dec 1, 2017 at 5:22:04 am
I now have a 4K UHD TV. I don't have 4K video camera. I do have hundreds of stills that are well above the 3840 × 2160 resolution.
Would they be suitable for making a slideshow? What codec would you recommend? The TV can play back HEVC/H.265.
Thanks in advance
Paul Gregory
Re: Create Slideshow in 4K
on Dec 13, 2017 at 4:01:28 am
I can't believe that no one has ever done this?
Thanks in advance
Robert Strong
on Dec 14, 2017 at 5:08:41 am
I have been watching your post for many days, hoping for a reply to your question . I too have many hi res pics that I would love to try in a 4k project. But I don't have a 4k tv yet.
I keep checking and hoping for a response to this post.
robert
Videographer, editor
Refrigerated water cooled PC i7- 6950X.
Win 7 64 bit, 64Gb DDR4, Nvidia GTX580.
Sony HVR-Z5U, HVR- V1U, HVR-A1U, HDR-HC3.
Canon MK2 5D, SX50HS, GoPro Hero2.
Nikon CoolPix P510
Paul Berk
on Dec 14, 2017 at 5:38:02 pm
I don't have any 4K displays so I can't try it but I can't see any reason this would not work in Vegas. Set project properties to 4K, render to 4K template. That should do it ... right?
Mark Wilson
on Dec 15, 2017 at 1:50:36 am
Yes. 4k slideshows work just the same as SD or HD .
I would set up your project for UHD resolution, do all your slideshow moves, and then export using either the Intel HEVC codec (UHD preset) or some flavor of h.264 (will have to make your own preset). I have done both, but prefer HEVC. It is slow but reliable.
FYI, unless you stand within about 6 feet of your TV you will be hard pressed to see a difference between UHD renders and high bitrate HD. Try a couple short test renders to see.
