Trouble with PAL capture - rolling image
COW Forums : VEGAS Pro
John Romein
on Nov 23, 2017 at 3:29:33 am
I'm using Vegas Pro 14, Canopus 110, and a Sony CCD-TRV69E - PAL Hi8 camcorder.
For the NTSC tapes we use a Sony deck plugged into the Canopus box and we have no trouble.
For PAL tapes we use the camcorder plugged into the Canopus. On the capture window in Vegas we get the audio, correct color, and the image but it is constantly rolling.
For setup, we switched the Canopus dip switch 6 to on (PAL) and everything else is left off (this was done with power off). In Vegas vidcap we also changed the Capture preferences under the capture tab we checked the box and set "custom frame rate" from NTSC to PAL and under the preview tab we left the "pixel aspect" automatic.
What am I missing?
John
Win10 Pro
Graham Bernard
Re: Trouble with PAL capture - rolling image
on Nov 23, 2017 at 3:58:59 am
Sounds like you’ve done everything correctly. Can you Preview the PAL tape in the PAL Camera? Is it rolling there?
* Grazie
John Romein
on Nov 23, 2017 at 5:31:29 am
The Sony camcorder we use to read the PAL tape is previewing perfectly.
It must be a setting somewhere that I've missed? I've sure it is something simple!
John
John Romein
on Nov 24, 2017 at 9:32:26 pm
Duh! Turns out the tape we thought was PAL was NTSC.
Works fine now with NTSC settings!
John
Graham Bernard
on Nov 24, 2017 at 10:12:12 pm
Aaaarrrrggghhhhhhhh.....
* Grazie
