Audio Envelope Points
COW Forums : VEGAS Pro
John Perez
on Nov 12, 2017 at 2:27:28 pm
Is there a faster way to delete/work with audio envelope points rather than right-clicking/delete?
HP Intel(R) Core i-7 CPU
950 @3.07G 3.07
RAM: 8 Gigs
64 Bit Op System
As always thanks so much to you guys...Johnny In Orlando
Danny Hays
Re: Audio Envelope Points
on Nov 12, 2017 at 4:12:04 pm
You can delete or reset the envelope, and start over.
Danny Hays
Samples of my Work can be seen here:
https://www.youtube.com/user/ErnestDaniels/videos?view_as=public
John Norton
on Nov 13, 2017 at 12:26:33 am
If you “select” the audio envelope tool at the bottom, default is not selected, then by creating a time selection above the audio envelope points that are of interest to you, you can for example delete only those auto selected points.
John Norton
on Nov 13, 2017 at 12:43:52 am
Couldn’t see how to edit my post.
Meant to say that it appears that to un-select the envelope edit tool then select the normal edit tool.
For example ... With normal edit tool selected, envelope edit tool not selected, create a time selection, drag the audio envelope say down, within the selected area to auto create 4 envelope points. Now if you wantesd to delete these or any other points (besides ctrl-z) select the envelope edit tool, draw timeline selection and press the del key.
