Chart for rendering settings
COW Forums : VEGAS Pro
Linda O'Connell
on Nov 6, 2017 at 2:35:35 pm
For the past 10 years I have been using a chart that shows what settings to use when making a DVD based upon length of the project.
I have had it sitting here and now it has disappeared!
Does anyone know where I can get a copy?
Graham Bernard
Re: Chart for rendering settings
on Nov 6, 2017 at 3:06:32 pm
[Linda O'Connell] "Does anyone know where I can get a copy?"
I don’t remember seeing it, but was it John Meyers DVD chart? I’ve had a trawl of the Vegas forums and can’t find it. I’ve been using Marks Bitrate calculator which is real-time calculator that’s held me in good stead over the years.
* Grazie
Jorma Nippala
on Nov 6, 2017 at 3:16:23 pm
Yes, it seems John Meyer's chart links there do not open any more, but here's "Mark's DVD BitRate Calculator" http://www.johncline.com/bitcalc110.zip
Linda O'Connell
on Nov 6, 2017 at 4:16:41 pm
Yes, I believe it was John's chart. But I can make the other work. Thank you!
Graham Bernard
on Nov 6, 2017 at 4:33:48 pm
[Linda O'Connell] "But I can make the other work."
Sure. It’s very easy to get results and the tweaking is superb. Having done some further research, Johns chart may have been a Spreadsheet? Yes?
* Grazie
Francois Pénzes
on Nov 7, 2017 at 2:33:46 am
Hi Jorma
Do you still have the old or broken link(s) ?
PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz NVIDIA GEFORCE GTX 550 Ti
Cameras: Canon XF305 + Canon XH-A1
Blackmagic HyperDeck Studio Mini
''When the cutting stops, the editing begins...''
Jorma Nippala
on Nov 7, 2017 at 11:20:05 am
Francois, the links are in old SCS forum threads archived on http://forum-archive.magix.info/home. Searching there (Words) calculator and (User) johnmeyer returns 100+ threads starting from 2003 (https://www.vegascreativesoftware.info/us/forum/help-on-mpeg-2-encoding-to-dvda--15972/).
Many later threads also with the same link and another link from 2011 https://www.vegascreativesoftware.info/us/forum/dvd-capacity-vs-bitrate-cal.... There may be a couple others, but none of them worked or gave the right file (the spreadsheet Graham mentioned) even trying with Wayback Machine.
Francois Pénzes
on Nov 8, 2017 at 10:39:55 am
Hi Jorma
Thx Jorma ! To bad some good stuff gets deleted.
Found this link. Maybe it'll help.
http://www.sonyvegas.co.uk/rendering-tips-for-dvd-a-by-john-meyer/
Cheers !
Jorma Nippala
on Nov 8, 2017 at 1:36:03 pm
Francois, both calculators linked there are often recommended, in fact the second one was mentioned earlier in this thread. I don't think the page mentions the johnmeyer Excel spreadsheet calculator. A "quick and dirty" table is in his post here. You can compare that with a larger table from jetdv.com/.
While we're at it, there's an old (still working) spreadsheet calculator link here. I didn't try it.
Francois Pénzes
on Nov 9, 2017 at 1:22:59 am
Thx Jorma !
Cheers !
