White Balance Effect mission
COW Forums : VEGAS Pro
Greg Prickril
on Nov 1, 2017 at 2:51:41 pm
Installed Vegas 14 and can no longer find the White Balance effect. Any ideas what's going on? Has it been retired? What's the replacement? Thanks.
Francois Pénzes
Re: White Balance Effect mission
on Nov 2, 2017 at 12:08:15 am
Hi Greg
Still there for me...
PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz NVIDIA GEFORCE GTX 550 Ti
Cameras: Canon XF305 + Canon XH-A1
Blackmagic HyperDeck Studio Mini
''When the cutting stops, the editing begins...''
Aaron Star
on Nov 2, 2017 at 3:59:42 am
Using the color correct effect (the one with the color wheels for high/med/low) and the eye dropper tools, you can achieve the same effect. Actually you probably will get better color balance that way.
  • Low - use the add or subtract on a black shadow area or a color you want black.
  • Mid - use either eye dropper tool on a medium white tone or grey.
  • High - use either eye dropper on an area of white in your scene.
The RGB histogram will show you the color imbalance. The RGB peaks should roughly align, based on how much warmth or cool tone you want in your image.
Shoot a chip chart while you are shooting, and you can pretty much just eye drop the black/medium/white areas of the chart. You can use the crop/zoom tool to punch in on the chart to make it full screen. Then use the waveforms/histogram to level the shot.
