4k Cell Phone Video Won't Work in Vegas 10. Solution? :)
COW Forums : VEGAS Pro
Steve Ujvagi
on Oct 14, 2017 at 9:13:20 pm
Obviously, using Vegas 10, I'm not a heavy Vegas user. I took some 4k footage using my iPhone. (don't judge me) I can get the file into Vegas but it doesn't respond normally and when I try to render any of it it gives me an error message letting me know I need Quicktime 7.1.6 or later on my computer. I downloaded the latest Quicktime version. Still no bueno. I'm on Windows. I did a search on this forum but I did not see a similar issue.
Help?
Francois Pénzes
Re: 4k Cell Phone Video Won't Work in Vegas 10. Solution? :)
on Oct 14, 2017 at 9:22:57 pm
Hi Steve
Mediainfo on your file would be nice to have in order to troubleshoot. Could be your frame rate, file type, etc...
https://sourceforge.net/projects/mediainfo/
Cheers !
PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz NVIDIA GEFORCE GTX 550 Ti
Cameras: Canon XF305 + Canon XH-A1
Blackmagic HyperDeck Studio Mini
''When the cutting stops, the editing begins...''
Steve Ujvagi
on Oct 18, 2017 at 1:07:47 pm
54 seconds of video shot on an iPhone at the "4k at 30 fps" setting.
3840 x 2160
Quicktime .mov
291mb file size
Video data rate 45125 kbps
Video total bit rate 45214
I'm an amateur. ☹ I hope that info helps you help me.
Thank you.
Francois Pénzes
on Oct 18, 2017 at 1:49:25 pm
Hi Steve
A full Mediainfo result would have given me a lot more information about your file. Unfortunately I don't have enough to work with.
Is it possible for you to copy and paste the full result ?
Something like this for example: 11772_example.txt.zip
Cheers !
Ole Kristiansen
on Oct 18, 2017 at 1:58:23 pm
Hi
Try convert your footage to mp4 with Handbrake - with constant framerate !
Best,
Ole
