Weird artifacts in preview and render, not in file
COW Forums : VEGAS Pro
Ilgar Aminabadi
on Oct 14, 2017 at 6:39:01 pm
Vegas Pro 13 decides that today it wants to mess up my AVI file. The render settings are set to a preset and match the video, so nothing should be going wrong.
Francois Pénzes
Re: Weird artifacts in preview and render, not in file
on Oct 14, 2017 at 9:32:06 pm
Hi Ilgar
Keep in mind that an .AVI is just a container for a video and/or audio file.
Mediainfo your original video file so we may help you.
https://sourceforge.net/projects/mediainfo/
For more in-depth info;
https://en.wikipedia.org/wiki/Comparison_of_video_container_formats
PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz NVIDIA GEFORCE GTX 550 Ti
Cameras: Canon XF305 + Canon XH-A1
Blackmagic HyperDeck Studio Mini
''When the cutting stops, the editing begins...''
Ilgar Aminabadi
on Oct 17, 2017 at 3:33:05 am
Here is a text file, made by MediaInfo, about the original file.
11764_example.txt.zip
Francois Pénzes
on Oct 17, 2017 at 10:25:04 pm
Hi Ilgar
When you render, what is your field order ?
You get artifacts sometimes when there is a conversion from interlaced to progressive somewhere along the process.
If that fails, try rendering part of your original file in another format an see if you get the same result.
Cheers !
