 | Drop frames in Sony Vegas 13
on Oct 1, 2017 at 8:21:06 am |
We face heavy drop frames in Sony Vegas 13 while capturing from Umatic and betcam tapes using blackmagic capture card.
Pls let me know what should be the ideal system configuration.
Fanil Joshi
 | Re: Drop frames in Sony Vegas 13 on Oct 3, 2017 at 11:01:26 pm |
Which Blackmagic devices and software driver version are you using?
Have you tried capturing with the Blackmagic capture application that installs with the driver? Does that application drop frames as well?
What are your system specs?
I would not use the Vegas Capture tool. I would use the Blackmagic utility for capture, then edit the captured footage with vegas.
