Zooming without black borders appearing?
COW Forums : VEGAS Pro
Jeff David
on Sep 29, 2017 at 9:38:28 pm
I know that I can change the properties and deselect, "loop" and "maintain aspect ratios" and sometimes that will eliminate the black borders when zooming - depending on the size and dimensions of the clip.
Of course, that does not always work depending on the size and dimension. So in those cases, is there a way to have the black borders not appear as the clip zooms?
Lenovo quad core i7 16gb of ram, Windows 8.1 MS 13 64 bit Thumbnail is view out of the Olde North Church window where the signal lanterns were hung, as in, "1 if by land 2 if by sea" looking across the Charles River to the Charlestown Naval Yard where rebels awaited the signal April 18th, 1775.
Lex Ger
Re: Zooming without black borders appearing?
on Oct 4, 2017 at 12:11:56 am
try this.
use Pan/Crop > Make Output Aspect
