Vegas 15 Pro slow-mo settings?
COW Forums : VEGAS Pro
Bob Mark
on Sep 16, 2017 at 3:14:12 pm
Hello. I have some 1920x1080 29:97 progressive footage and when I try to slow-mo it, it looks "ghosty" and interlaced.
What is a good setting for smoother slow-mo? Also, can you set the velocity rate with the keyboard?
In the old days we would duplicate the clip and put it below on another track, offset it by one frame, and then make the top clip 50% transparent.
Thanks.
Bob
Graham Bernard
Re: Vegas 15 Pro slow-mo settings?
on Sep 16, 2017 at 7:46:09 pm
Try the "Disable Resampling" Switch at the Event level. You can get better. But now I've thrown in the towel and purchased the Mighty TWIXTOR. It was on offer years back by SONY. Gets me smooth solid slomo with 24p. But even still, I need to Disable Resampling.
[Bob Mark] "Also, can you set the velocity rate with the keyboard?"
Which part of the process?
* Grazie
Bob Mark
on Sep 17, 2017 at 3:01:09 pm
Thanks for that info about the sampling and Twixtor. I want to set the % of velocity with the keyboard, not by dragging a line down. Thank you.
Bob
