Can't add more than 1 effect
COW Forums : VEGAS Pro
Avanis Apollon
on Sep 12, 2017 at 11:34:59 pm
Hi, I'm currently using Vegas Pro 13 and I had a little problem that holds me back from making my video.
I've downloaded a pack with some effects and I successfully installed them with the Preset Manager, when I tried adding an effect, it worked, but when I tried to add a second effect in the same clip, the first effect was replaced with the new one, I can't add more than 1 effect without getting the first effect replaced.
This only happens with the pack that I downloaded, when I add the default effects of Sony Vegas, I can add more than one without any problems, but with the pack that I downloaded, it doesn't work, I also tried another pack, but I had the same problem. This how my panel looks like: https://prnt.sc/gkfx2v I click on 1 effect, I add it, I click on another effect, click on ADD, it replaces the other one that I added before with this one.
Any help would be appreciated, thanks!
