Video effects wont apply unless I close the FX window
COW Forums : VEGAS Pro
Stanescu Theodor
on Sep 11, 2017 at 10:13:55 pm
So the title says is all , I go into Event FX, try to do some color correction, nothing happens when changing values, i exit the window and the effects are applied.
It's driving me bonkers , cause I have to do this for every single shot I filmed.
George Dean
Re: Video effects wont apply unless I close the FX window
on Sep 12, 2017 at 2:38:47 pm
Hi Stanescu,
Click on the split screen icon above the preview window (not the drop down menu, just the icon). This will toggle fx in the preview window on/off.
Best Regards.....George
Stanescu Theodor
on Sep 12, 2017 at 3:16:38 pm
Hi George. I tried that. The problem isn't that it's not showing my effects, it's that it only happens after closing the FX window. Oddly enough, this glitch isn't happening with the curves graph , i can modify it and see the results in real time
Marco Baer
on Sep 12, 2017 at 7:18:02 pm
Did you try turning GPU support off in "Options/Preferences/Video"?
George Dean
on Sep 12, 2017 at 11:54:51 pm
Sorry Stanescu,
I understand better now what your issue is. I cannot duplicate it in MVP15 or SVP13 for Color Correction or Color Curves. Mine are working as normal with or without GPU support.
Ethan Nunn
on Sep 13, 2017 at 12:16:16 am
I had this issue for a while now in Vegas 15 but turning off GPU acceleration fixed it for me. Try turning it off and see if it fixes it.
