Nothing will render out
COW Forums : VEGAS Pro
John Perez
on Sep 4, 2017 at 2:13:47 am
Hi All, project will not render out whether I try to do entire timeline( 5 minutes) or just bits of it. Created new timeline and imported one event and still nothing (crashes). Please help!
HP Intel(R) Core i-7 CPU
950 @3.07G 3.07
RAM: 8 Gigs
64 Bit Op System
As always thanks so much to you guys...Johnny In Orlando
Graham Bernard
Re: Nothing will render out
on Sep 4, 2017 at 3:41:00 am
[John Perez] "Please help!"
Come on John, you've been here years, you know what we need to help you, more info..... Without this we'd be punching in the dark. Once we can see no "obvious" brakes on your rendering, then we can go with a deeper analysis.
However, be assured, I can render well with all sorts of FXing and combos.
* Grazie
John Perez
on Sep 4, 2017 at 1:33:48 pm
Well, you've got my Computer information. This is what happens: I choose my render space on the timeline; go to Render As, then it freezes. That's it. The blue circle goes round and round finally getting the "stopped working" menu. In other words I never get to the formats/codes menu. I don't even make it that far. I'm running V13. And I've tried all the solutions I can find on the internet. Anymore info from me? Thanks
950 @3.07G 3.07
RAM: 8 Gigs
64 Bit Op System
Ole Kristiansen
on Sep 4, 2017 at 1:40:17 pm
Hi John
What kind of video footage are you working with ?
best,
Ole
John Perez
on Sep 4, 2017 at 2:12:18 pm
.MOV's from Blackmagic Design Pocket Cinema Camera. But the problem is not with the nature of the footage. I created a new instance, loaded a simple generated media and tried to render that and it still had the same problem. I think it's got to be a hardware issue.
950 @3.07G 3.07
RAM: 8 Gigs
64 Bit Op System
Graham Bernard
on Sep 4, 2017 at 1:42:23 pm
Project Settings
Media Format
* Grazie
John Perez
on Sep 4, 2017 at 2:13:31 pm
>mov's from Pocket Cinema Camera. 1080i
950 @3.07G 3.07
RAM: 8 Gigs
64 Bit Op System
George Dean
on Sep 4, 2017 at 2:19:15 pm
What OS are you using?
Have you had any recent updates to the OS or GPU?
Have you disabled the GPU?
Have you tried a program reset and deleted the cached application data?
If on Win7, when it locks up, have you tried, Shift+Alt+Del, click on Start Task Manager, when the Task Manager window appears close it. This may unlock the program.
John Perez
on Sep 4, 2017 at 2:50:35 pm
Wow, George those are great questions. Let me work to get the answers back to you. (I have disabled the GPU acceleration suggested by a You Tuber. I wanted to switch GPU back to my NVIDIA card and that option wasn't there. I'm running Win 10, last updated in 2015?)
950 @3.07G 3.07
RAM: 8 Gigs
64 Bit Op System
John Perez
on Sep 4, 2017 at 9:58:19 pm
George,
I'm running Win10. I tried all your suggestions to no avail: Installed new drivers for NVIDIA GPU, reset program with cache clean, and started Task manager then closed it to no effect. Well guys, I'm at the end of my rope, here. (And to think today held so much promise. NOT. Maybe my computer guy will figure it out...)
950 @3.07G 3.07
RAM: 8 Gigs
64 Bit Op System
John Perez
on Sep 4, 2017 at 10:03:04 pm
George,
I'm running Win10. I tried all your suggestions to no avail: Installed new drivers for NVIDIA GPU, reset program with cache clean, and start Task manager to no effect. Well guys, I'm at the end of my rope. (And to think today held so much promise. NOT. Maybe my computer guy will figure it out...
Now the application freezes at start. Doesn't even open up!
950 @3.07G 3.07
RAM: 8 Gigs
64 Bit Op System
George Dean
on Sep 5, 2017 at 12:01:19 am
Hi Johnny, it sounds like you are doing a 'loop region' render, is that correct?
I am using Windows 7 and cannot help with your OS, as I have no experience with it. You might want to fall back a couple of driver versions (or at least one) of your Nvidia card. When I was using an older Nvidia card the updates started to cause issues, so I went back to the previous version I stopped updating them. Although this just doesn't sound like a GPU issue to me.
Maybe you are at the point of needing the make a clean uninstall and then clean install of your v13. Hopefully someone else here will have a suggestion.
Lex Ger
on Sep 7, 2017 at 3:43:27 pm
did you try to delete the .sfk files?
or render to another hard drive..
