How do I set it so that by default, it does not "maintain to fix aspect ratio"?
COW Forums : VEGAS Pro
tony chen
on Aug 31, 2017 at 3:45:31 am
So every time I try to drag an image over a video (whose aspect ratio is not the same as video), it tends to crop out the edges. I have to manually drag the borders so that I can see the entire image on the screen. Is there a default setting for this?
Here is the problem: http://i.imgur.com/PXOoufk.png
