Vegas Pro 14 Suite vs Vegas Pro 15 Suite - rendering speed test benchmark
COW Forums : VEGAS Pro
Marcin Zmyslowski
on Aug 29, 2017 at 11:03:36 am
Hello!
Video presents benchmark rendering speed test in Magix Vegas Pro 14 Suite vs Magix Vegas Pro 15 Suite.
Rendering speed test was taken on the following PC:
CPU: Intel i9-7900X (20 threads)
GPU: Nvidia GTX 980 TI
Memory Flash SSD: Samsung 960 EVO M.2
System: Windows 10 Home
RAM: 64 GB
Video presents CPU Load, GPU Load, rendering time on both Vegas Pro 14 and 15.
Input video raw file: 4K AVC 29.97fps 60 Mbps - duration: 2 min. 30 sec
Output video file: 4K XAVC S 29.97fps 60 Mbps - czas: 2 min. i 30 sec.
Here is a link to the video:
Kindest regards
Marcin from Poland
Nigel O'Neill
Re: Vegas Pro 14 Suite vs Vegas Pro 15 Suite - rendering speed test benchmark
on Aug 29, 2017 at 10:35:29 pm
In short: 11 minutes 19 seconds using v14 and 9m 35s under v15 under the same conditions
My system specs: Intel i7 7700k 4.20 GHz, GTX570, 16GB RAM, Gigabye Z170 HD3, Vegas Pro 12 (x64), Windows 10 x64 Pro, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
Ryan Gray
on Sep 26, 2017 at 4:24:44 am
What is the absolute BEST graphic card for rendering 4K material down to HD 1080p files or 480p (DVD) files? I have an AMD Ryzen processor and an AMD RX 580 GPU....but sometimes during rendering in Vegas Pro 13 it does fine and then inexplicably stops and says 0 frames rendered, black screen. Nada. Don't know what is causing this. Is there a better card that I should use? Or should I upgrade to VP14 or 15, do they handle 4K any better?
