Video lags
COW Forums : VEGAS Pro
Tommy Sewell
Video lags
on Aug 2, 2017 at 10:09:09 pm
Hello All,
I have had a problem with one specific video for a few months and am seeking answers. I have an unboxing which can be found here
and it starts to get choppy when I cut open the box and view the contents. I know the computer(s) I have been using aren't THE BEST and my Vegas is old but due to not enough funds can't upgrade, however I never had a problem like this before.
I use Sony Vegas Platinum 10
PC Specs
Processor
Class: AMD Phenom(tm) 9950 Quad-Core Processor
8GB RAM
GeForce GT 730
I try to render as a MainConcept MP4
Stereo, AAC
Video: 29.970 fps, 1920x1080 Progressive, YUV, 15 Mbps
Pixel Aspect Ratio: 1.000
Or a Sony AVC
Audio: 192 Kbps, 48,000 Hz, 32 Bit, Stereo, AAC
Video: 29.970 fps, 1920x1080 Progressive, YUV, 8 Mbps
Tried with a variable Bitrate and Constant. Also tried rendering as a WMV
The clips have a FPS as 29.02 because I converted them from my Note 5 with VLC because it wouldn't open but the source files look great. Any help would be appreciated as I would like to have the video look good.
Francois Pénzes
Re: Video lags
on Aug 4, 2017 at 12:51:06 am
Hi Tommy
If I am reading correctly, your original file that you dropped in Vegas has a 29.02 FPS. Vegas doesn't like that very much.
It's always trying to catch-up, hence the choppiness.
Try converting your file to a 29.970 FPS and that should do the trick. You can use Handbrake or any other decent converter.
VLC has a built in feature that does caching in order to deliver the output at a steady rate.
Never base the quality of your footage on the output from VLC.
Don't get me wrong, VLC is a great player, just not a good reference.
Cheers !
PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz NVIDIA GEFORCE GTX 550 Ti
Cameras: Canon XF305 + Canon XH-A1
''When the cutting stops, the editing begins...''
Steve Rhoden
Re: Video lags
on Aug 4, 2017 at 12:12:58 pm
The 29.02 FPS is the cause of your issues as Francois also mentioned,
Convert them first to 29.970 FPS
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
