vegas pro 14 - project properties not saved properly when restart
COW Forums : VEGAS Pro
Wilfried Van
on Jul 17, 2017 at 9:52:54 am
Vegas Pro 14 has added disable resample in project properties , which is excellent but now it does not save and remember the " view transform " setting.
Everytime I do restart vegas , I do have to go into project properties and change the view transform to " OFF " since that is always restarted as " ACES ".
My project properties are to be 32 bit floating point ( full range ) and view transform OFF . ( since vegas pro ... long time ).
Of course I am aware that after correct setting all settings , I have to save and apply these settings when starting.
This is a simple but VERY annoying issue introduced in vegas pro 14 ( 270 )
( am working on very powerfull HP Z820's systems solely used for editing and nothing else )
Graham Bernard
Re: vegas pro 14 - project properties not saved properly when restart
on Jul 17, 2017 at 12:55:23 pm
[Wilfried Van] "My project properties are to be 32 bit floating point ( full range ) and view transform OFF ."
Are you saying this is for existing projects, or new projects? Had you used the "Start all new projects with these settings" - I just did with your settings and a new projects holds your settings.
Maybe I'm missing something?
* Grazie
Wilfried Van
on Jul 17, 2017 at 2:53:45 pm
Hi Graham ,
Open vegas ( without a project ) for first time and set project properties properly , save and of course "Start all new projects with these settings" . ( am using vegas since version 4 and this basics I do know in meanwhile ☺ ) .
Now close vegas .
Re-open Vegas and everything BUT " view transform " is correct in project properties ( ie the OFF changed into ACES ).
Wilfried
Graham Bernard
on Jul 17, 2017 at 3:03:45 pm
Beat yah! I started with VV3 . . .
Sorry, I can't repro your issue.
* Grazie
Wilfried Van
on Jul 17, 2017 at 4:09:47 pm
Maybe I am not clear enough ☺
Start vegas , do not load anything , just set the properties and set the " apply these for all new projects " and press apply.
Now exit vegas .
Restart vegas and verify the project properties -> all are correct but view transform ( ACES instead of OFF ).
When saving a veg file with the properties , it reloads fine with all the project properties correct but each time vegas is started again and nothing yet loaded ( no veg file , vegas just opens ) the properties are again view transform to ACES instead of OFF .
Bizar
