Vegas Pro 14 rendering imported video without any compression.
COW Forums : VEGAS Pro
Seetha Ramaiah Velicheti
on Jun 26, 2017 at 9:25:32 am
Sir, I have Vegas Pro 14. My cameraman gave me my music concert video of a 32 GB Movie Clip (.mpeg) uncompressed. I imported the same into timeline, just cut a small unwanted portion. Now I wish to render out the same Movie Clip (.mpeg) uncompressed in its original form without any changes by Vegas Pro 14. How to do it Sir.
John Rofrano
Re: Vegas Pro 14 rendering imported video without any compression.
on Jun 26, 2017 at 3:36:59 pm
[Seetha Ramaiah Velicheti] "I wish to render out the same Movie Clip (.mpeg) uncompressed in its original form without any changes by Vegas Pro 14."
Your video is most likely not "uncompressed" if it's in a file with .mpeg extension. It is more than likely compressed as MPEG-2.
Vegas Pro can smart render MPEG-2 for files such as those from HDV and DVD camcorders but your MPEG-2 file might not be one of these. In order to perform smart rendering, the width, height, frame rate, field order, profile, level, and bit rate of the source media, project settings, and rendering template must match. Frames that have effects, compositing, or transitions applied will be rendered.
Try using the MainConcept MPEG2 encoder to see if you can match these parameters. If you can, you will see a black window when rendering that says, "Compression not required". Unless you can exactly match these values, Vegas Pro will re-render the video.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
on Jun 26, 2017 at 5:21:37 pm
"Sir, I have Vegas Pro 14. My cameraman gave me my music concert video of a 32 GB Movie Clip (.mpeg) uncompressed. I imported the same into timeline, just cut a small unwanted portion. Now I wish to render out the same Movie Clip (.mpeg) uncompressed in its original form without any changes by Vegas Pro 14. How to do it Sir."
The above was my earlier question. I wish to elaborate. My cameraman shoots in .MTS format. He loads it in its Adobe Premier and after editing, he gives a movie clip(.mpeg) file of about 32 GB for a 3 hour concert.
I import that .mpeg file into the timeline of Vegas Pro 14, cut some more length of video, Now since that quality is much better than my .mp4, I wish to just render the same .mpeg format without any additions or deletions by Vegas Pro 14.
I will try as to suggested Sir. Thankyou very much for your great advice. Best Regards,
Seetha Ramaiah.
John Rofrano
on Jun 26, 2017 at 9:32:47 pm
You're welcome. Let us know how you make out.
~jr
