Sony Vegas 14 Crashes while rendering
COW Forums : VEGAS Pro
Khanh Luong
on Jun 26, 2017 at 2:12:58 am
I recently upgraded to SV14, and ive been working on a really heavy project. Usually at like 95% when I'm almost done rendering it will crash. I've tried all the fixes on youtube and nothing has worked. I've never had this many crashes on 13 before and I would like to know the fix. The only reason I'm even staying on 14 right now is because my project I've spent 10+ hours editing is on here and I cant run it on 13.
Here's what it says:
Problem Description
Application Name: VEGAS Pro
Application Version: Version 14.0 (Build 161) 64-bit
Problem: Unmanaged Exception (0xc0000005)
Fault Module: C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9247_none_08e394a1a83e212f\MSVCR90.dll
Fault Address: 0x00000000754AE293
Fault Offset: 0x000000000001E293
Fault Process Details
Process Path: C:\Program Files\VEGAS\VEGAS Pro 14.0\vegas140.exe
Process Version: Version 14.0 (Build 161) 64-bit
Process Description: VEGAS Pro
Process Image Date: 2016-09-13 (Tue Sep 13) 20:47:24
Shunichi Daido
Re: Sony Vegas 14 Crashes while rendering
on Jun 26, 2017 at 5:11:23 am
I wonder if this page will give you some more things to try in order to fix the problem presumably related to MSVCR90.dll.
https://www.vegascreativesoftware.info/us/forum/crash-due-to-msvcr90-dll--8...
Meanwhile, if Vegas Pro 13 works more stably than Vegas Pro 14, then I suggest that you convert the project file via the following utility and resume working in Vegas Pro 13.
http://www.focusonvegas.com/movie-studio-vegas-pro-version-faker/
