Vegas Pro 13.0 - "An error occurred while creating the media file [...]. The reason for the error could not be determined."
COW Forums : VEGAS Pro
Andreas Pichler
on May 14, 2017 at 4:33:20 pm
When i try to render my project this is the error message shown:
Every solution found on the internet suggested rendering CPU-Only which i already did.
Some suggested that it could be the lack of space on the HDD.
system drive: 18GB Free
drive where project gets rendered to: 2TB Free
By now i have not found a solution working for me. Hope someone can help.
László Kovács
Re: Vegas Pro 13.0 - "An error occurred while creating the media file [...]. The reason for the error could not be determined."
on May 14, 2017 at 8:06:00 pm
another reason can be if very bad render settings are specified. For a really wild example, mpeg with 575*357 resolution.
So what are your project/render settings?
Best regards
László Kovács
Andreas Pichler
on May 14, 2017 at 9:03:29 pm
thank you for your answer.
My project/render settings are 1920x1080/60fps/28Mbps
Best regards
László Kovács
on May 15, 2017 at 4:13:20 am
full HD 60p @28Mbps what? MXF? AVC? (Sony or Mainconcept?)
Did you tweak any render setting? If yes, what setting of which template?
If not, which template do you try to render to?
Do you have write peission in the folder where you need to place the rendered file?
Best regards
László Kovács
Andreas Pichler
on May 15, 2017 at 10:51:30 am
Full HD 60fps @28Mbps MainConcept AVC/AAC
I tweaked the template Internet HD 1080p changing frame rate to 60 and the bit rate to 28Mbps.
I do have write permission in the folder im rendering to.
Best regards
László Kovács
on May 15, 2017 at 11:10:36 am
It should work.
If you did not tweak any other settings, it should work.
I did the same here just right now.
Took the builtin 1080p template, changed bitrate (both avg and max) to 28 Mbps.
I changed then the framerate, first tried 59,940 (double NTSC) then tried 60,000 too.
Both worked.
Does the file exist you are trying to render to?
If yes, is it possible, that this file is open and locked (maybe by Vegas itself, for example if you try to overwrite a file via render, but that file is also part of the project - it's on the timeline or somewhere in the media bin)?
Best regards
László Kovács
Andreas Pichler
on May 15, 2017 at 12:33:51 pm
It works fine when i use the standard Internet 1080p template but as soon as i change something the error occurs.
I render to a completely new file everytime not overwriting any existing file.
Best regards
László Kovács
on May 15, 2017 at 2:06:02 pm
I'm out of ideas, sorry.
I have V13 build 545, which is already a Magix build. If you have build 453 which is the latest Sony build (I think), that may have a bug...
You may try Vegas14 trial, just to see if it works as you expect it to work?
Best regards
László Kovács
Andreas Pichler
on May 15, 2017 at 9:09:38 pm
I tried using Vegas 14 and it worked the first time. Now its the same as in Vegas 13, as soon as i tweak some render settings the error occurs.
I took a look at everything but the time of occurence seems to be totally random. Still, thank you for helping.
Best regards
László Kovács
on May 16, 2017 at 6:26:41 pm
You're welcome.
All this suggest me, that the prolem is specific to your computer, and it's not really a Vegas roblem.
I'd try to reinstall the OS and Vegas (on a separate new HDD), just to try if it's still present.
If the reinstall does not cure, then I don't know...
But you'll still have your original HDD with the original installations.
Best regards
László Kovács
